The US Stove is a pretty basic stove (no tstat, no auto ignite)
NOISE: the stove in general is pretty loud; the air coming through the top of the stove sounds like a turbine hissing and the auger motor is clearly heard when it turns on and off (not overly loud, just obviously heard); there is not much room in the burn pot for the agitator so if you don’t scrape it regularly the agitator will hang up on the burn pot, lift it and then allow it to bang back down (cleaning issue not stove problem);
APPEARANCE: you can get it with a trim package but mine is plain, flat black; looks good in a rustic living room but probably not great in a formal area
The stove puts out a good amount of heat; currently in an addition that is 24x36 separted into 3 rooms with 10’ ceilings
One side note is that the stove is advertised as a 60 lbs hopper but only one bag will fit, maybe all my bags are 60 instead of 40 lbs
Overall, I think the stove would be better in an area that you don’t spend a lot of time in due to the overall noise
$1200 paid, I am a little concerned that I already have a few problems not yet through one burning season but for the money not bad
!! Overall, I think the stove would be better in an area that you don’t spend a lot of time in due to the overall noise
