Exactly. Mine will run on UPS for an hour, gives me time to get the generator running... I then unplug the UPS, plug it into my generator and I'm good without stove shut down..The UPS doesn't run the stove it just supplies enough power for a proper shutdown. That might take 45 minutes so you need enough reserve battery to do this.
Rick... Get a Campion from Generators Direct. I have the 2K watt inverter one and I use it in my RV and around the house when I need portable 110 ac power to run power tools.I have been kicking around the idea of getting the small Honda knock off Predator inverter generator from China freight. But I know if it needs any parts on the future they probably are not available. For the little use it would get I hate to spend full Honda money...
Sorry bogie, the wattage is not just for the stoves wattage draw. It also is is an indicator/determination for battery type and size. UPS’s are actually designed for Computer/server interruption protection not really stoves. So if you want a ups for emergency shut down a 450 would handle the load but might not have enough storage to complete the task. The 750W would probably have enough battery to do it.
That is very helpful, I dont know much about generators. I always thought the Champions were junk due to there low price. But I guess notRick... Get a Campion from Generators Direct. I have the 2K watt inverter one and I use it in my RV and around the house when I need portable 110 ac power to run power tools.
The Champion is Chinese but built to their specification. It's a Lifan motor which is top of the Chinese heap, servo controlled throttle, auto idle down, quiet as a mouse and very frugal on fuel. and Champion has expendable parts like spark plugs and air filters available on the website (USA).
Very pleased with mine, it replaced a Yamaha inverter that was 15 years old.
I won't buy Honda power equipment. Over priced and I had a warranty issue on a Honda motor some years back (threw a rod) and Honda insisted it was my fault, even though the motor was only less than a month old. Needless to say that was it for Honda and me.
I recommend the Champion. Starts second pull every time too. Keep in mind that no matter what inverter you buy, the multi pole generator head will be a licensed by Yamaha product. Yamaha invented the multi pole dc head that is in all of them.
Mine is 5 years old, gets used a lot and is very reliable.
My issue with the HF Pred generators is like you, parts availability and because the inverters are electronic, no place to have it fixed if it does puke.
Maybe the box store ones that aren't PSW units. I have no use for one of those but the Champion Inverter has been flawless for me and it's lightweight too. Mine will run all night on eco throttle when I'm camping and it's very quiet, cannot even hear it running. Comes with a USDA approved spark arresting muffler too. Important when in the woods. I plug it into the RV, run it on eco throttle and let it decide on how fast it needs to run, depending on load. My wife and I both snooze on CPAP machines and it handles both of them and the RV no problem. It don't make enough amps to start a roof mount ac but then in the woods, I don't run the ac anyway. keeps the batteries charged, the machines running and runs the coffee pot in the morning too. I recommend them from real world testing, by me.... and, you can parallel 2 if you require more power and Champion sells the parallel kit. Not something I require however. Like a small suitcase with outlets.That is very helpful, I dont know much about generators. I always thought the Champions were junk due to there low price. But I guess not
I don't even do that. I just run the stihl pre-mix (has fuel stabilizer in it) and fire it up and run it regularly. It is sitting in the bed of the side by side presently in the heated shop.I also have a Champion Inverter 2000 watt generator also. Never had an issue with it, keep fresh ethanol free gas in it with stabilizer..
There are hour meters that just have a pig tail that wraps around the sparkplug wire. E free gas here is usually 50 cents more per gallon than regular gas, & 90 to 92 octane..I don't even do that. I just run the stihl pre-mix (has fuel stabilizer in it) and fire it up and run it regularly. It is sitting in the bed of the side by side presently in the heated shop.
E free gas is super expensive here, like 4+ a gallon. probably be 6 once the new administration gets done with their energy bs.
Never seen them in any box store being sold. Always the larger non PSW noise makers. Cabelas has them, seen them there but Generators Direct beats Cabelas price hands down and if I remember correctly, shipping was included.
Only thing I wish it had is an hour meter (my Yamaha did). Makes it easier to track oil changes, but I change mine every year and that seems to be sufficient, not that it hold a lot of oil anyway.
