Sting said:Since I first saw this while searching old posts - I have been wanting to ask what was used to make - or what was purchased for the exhaust fan?????
Jeremy Q said:Glad I found this maybe itll answer my questions. Its easier to ask them when you got sum pictures to refer to.Wow a 6"intake for combustion air. I dont know about sizing for this sorta thing, it just seems large to pull the draft, even with a blower fan on it. I didnt chase flow numbers, so I'm probably wrong, it dont sound like you have any problems with it. Do you think it would work better to have to run either smaller pipes or less on the 2' exchanger design? I think its a great idea/ add-on to the garn design. It has to be more surface area than just the 6"(a havent figured the numbers) even if you used say 1" pipe. What kinda blower is that on the transition chamber from the 6" to the 2" exchanger? Look quite thought out. Hope you dont mind all the questions. Im thrifty, my wife says just cheap, but why buy when you can build. N builds more fun and rewarding, at least 2 me (sick huh??)
