Upland 207 flue size question
dvellone
489
Does anybody have personal experience with the Upland 207 and if it might function acceptably utilizing a 6" ss insulated chimney installed inside the heated space and with a straight 19' run from the top of the stove to it's terminus 2' above the ridge? Thanks
It's supposed to be 7" but 6" straight-up would probably work.
Thanks. It's a temporary heater for construction, after which I'll be installing my Jotul.
In that case it should be fine. Be sure to maintain a generous clearance around it of 36" unless there is proper wall shielding.
