Hello
This is the 15th Magnum Baby Countryside I have seen and the 1st time I have seen the stop bolt broken. Just my experience. I have also seen less expensive auger motor shafts snap off. This maybe a severe case, but also it is the original 7/16" stop bolt on a 7 year old stove. See pic 1. One of the previous babies I worked on was a newer stove and as you can see in pic 2 has two stop bolts. The newer bronze color looks a little thicker and heavier. This customer had this stove for approx 3 years and no problem with the stop bolts. There are a two options in upgrading the stoves with the original stop bolt that may be older, stressed and possibly weak.
1. The first suggestion is to simply go to the hardware store and purchase a Grade 8 hex head bolt and replace the existing bolt. Grade 8 is stronger.
Example
http://www.allensfasteners.com/sear...tnSearch.y=6&gclid=CJmYhM663bcCFZOk4AodthYANA
2. As a more permanent fix, Magnum has a replacement bracket with new auger backing plate. This is a very strong bracket and the very best fix. I installed the plate per instructions and found it was still easy to get the allen wrench in there to tighten the auger collar set screw. It is also still easy to get the exhaust blower out, but you may have to remove the vacuum switch to clear the new auger motor mounting bracket. See pic 3,4,5
So far in testing I do not see any issues. Has anyone else tried this new bracket?
Pic 1 - Original 7/16" Hex head 3-1/2" long "stop bolt"
Pic 2 - Newer double stop bolt configuration
Pic 3 - New Auger Motor Mounting Bracket Front
Pic 4 - New Auger Motor Mounting Bracket Back
Pic 5 - New Auger Motor Mounting Bracket on stove with auger motor mounted
Example
