Upgrading an Old St Croix York Insert Digital Control panel
Don2222
9,187
Salem NH
Hello
This old St Croix York Insert serial # 003039 had a digital control panel with the #2 & #3 lights flashing at startup and would not fire up. Since there was no premium surge protection and no surge protection at all it died a slow death.
Since the stove would not run I did replace a low limit switch since the one in the stove fell apart and installed a new exhaust blower since the old one died but still the dreaded double 2&3 heat level lights flashing at startup was a show stopper!
The new upgraded part # 80P30523B-R board looks differennt had to be programmed for the the York stove and the extra connector on the back keeps the jumper that came installed in it.
To program the board after installing, plug in the stove
The slide switch must be set to manual, then
Simultaneously press and release
draft high, draft low and Auger Feed
Then watch all the heat level lights blink.
3 blinks is the St Croix York Insert Setup.
See pics
Has anyone seen the #2 & #3 heat level lights flash at the same time? ? ?
Also
Does anyone know the programming for each stove model?
How many blinks?
Pic 1 - New St Croix Upgraded Digital Control Panel
Pic 2 - Old St Croix Digital Control Panel
Pic 3 - St Croix fired up! It now works!
  • [Hearth.com] Upgrading an Old St Croix York Insert Digital Control panel
Nice work Don, thanks for info.
