Remove the micro-switch...did they give you a new slave for the feeder plate? Is that what I see in the picture in front of the burn pot?
Wholy cow man...4500 posts now? Addict.
Put one in in fall. Was a very simple install. Took me about 90 minutes taking my time.
Don - that stove was built in 1999 it took kit pn 1-00-06400
SXIPro - It makes the stove auto ignite
The kit I got had the control board, burn pot & gasket , ignitor & cradle & pusher arm. To my knowledge the do not specifically make a kit for the Invincible. I believe this kit will work on a an RS model but not the T. I saw a thread in here where they put one into a RS and made it work
https://www.hearth.com/talk/threads/5am-i-hit-the-office-guess-what.89921/#post-1173883
he used raw pieces to make his own kit - the kit plus wiring harness and burn pot plate from what I can tell is what he used
Don - You will see the micro switch when you pull the back of the stove - It is located on the side of the feeder assembly - the old pusher arm touches it each revolution of the feed motor. The new board has no where for it to plug into.
Yup and you will have to part with about $600 to do it.....Cool. Thanks. I'll have to look into if an upgrade is available for my old Invincible. Did you need to upgrade your control board as well?
Don
You must be specialYou got instructions. All I got was a manual for a P61A and a wiring diagram sticker and a box of parts.
Me too....although lately I use the propane torch.Looks like I'll stich with the old 'handsanitizer and a match' technique.
