Hello
Anyone try doing this? It works well once I got the manual feed adjust set properly.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Harman Pellet Pro II
Updated to work with new P61 Manual Circuit board and P61 Wire Harness. The combustion blower was also updated with the quick change housing and a new OEM Harman combustion blower with single paddle 4-3/4" diameter impeller blade. The Manual feed adjuster still works to adjust the feeder to avoid the 6 Blinks Status Error and to adjust for the quality of the wood pellets. In this case it is adjusted to 8 full turns to the left to prevent the 6 Blinks error so the stove works as it should. see video
It really cranks out the heat! The shop came up to 97 degrees F in no time flat!
