First post, but I've been reading for a while and am learning more and more (great info)...
I have an old log cabin in SW Wisconsin that I'm looking to do an update on the Stove and Hearth. We are in the process of getting our roof replaced and thought it would be a good time to update as the more I've read here, the more I've understood what was done wrong and where improvements might be made.
First, the cabin. roughly 6" rectangle logs, 35x20-ish, two story, upstairs is an open loft, downstairs there are no interior walls besides a 1/2 bath. The cabin roof and floors are uninsulated and the doors are homemade which all means we close up for the winter in roughly December and re-open in March or so. If the weather breaks enough mid-winter, I try and get a weekend in to make sure everything is ok as this is obviously a seasonal residence. We don't plan on insulating much more since it is part time. All of the heat is provided by the wood stove only. We have electricity but trying to do anything with heat would probably just be a waste.
We are there normally for the weekends only with some 3-4 day weekends, arriving on Friday so the cabin is whatever temperature it is outside. We generally get the stove as hot as we can when we arrive and then tuck in for bed while the cabin warms up. Generally I can get it from 30 or so degrees up to 60-ish by morning. However I only get about 3 hours of sleep at a time as the fire will burn itself out if I wait much longer. The wood stove is an old Scandia 318 smoker, with an 8" single-wall pipe. It passes through the roof with a few feet of Class A, then back to single wall from the looks, unknown brand installed by the old owner some 25-ish years ago. The chimney run currently is approximately 15 feet, straight up through the roof, mostly indoors.
My plan is to do one of two things, though I'm leaning towards #1 (looking for fast warm-ups, longer burn time primarily). I don't have a stove picked out, but I am set on replacing the chimney for sure as I don't think its safe:
1) Install new 6" double wall to new class A, adding 6' or more outside to lengthen the chimney above the roof peak. Along with the 6" pipe, shop for an updated stove of an appropriate btu for an uninsulated cabin, maybe an Englander w03/w08 or 32-nc. The lack of insulation makes btu estimates a crap-shoot. We generally stop coming up when the overnight temps dip below the 20's as it takes too much wood to keep it warm.
2) Find another old stove like a big Fisher or similar. Since we primarily only weekend heat, save a few bucks, get another old stove that has a good size firebox that will heat the cabin nicely. In any case, it'll get a new chimney as well. If we ever decide to live here full time, I can revisit the stove in 10 years or so.
Lots of typing and I'll attach some pics to help flush out details, looking for stove and/or chimney recommendations.
Thanks.
Tony
![Updated Stove in Log Cabin Updated Stove in Log Cabin](https://www.hearth.com/talk/data/attachments/281/281044-ac13de8dca01943a1ca33e0cb3c772a4.jpg)
Thanks.
Tony
![Updated Stove in Log Cabin Updated Stove in Log Cabin](https://www.hearth.com/talk/data/attachments/281/281042-8547e6ee1cd947acc62845db404209c3.jpg)
![Updated Stove in Log Cabin Updated Stove in Log Cabin](https://www.hearth.com/talk/data/attachments/281/281043-f6478aca5297eeb21c0d84259f093b1d.jpg)
