I am considering installing my stove myself--Woodstock Keystone in the basement, up through the first floor, and out through the roof. I think I have a straight shot, but there may be a surprise (or two) in the attic. I am pricing out Duratech products for now.
I am assuming that I should use double wall up to the support box. Would single wall be sufficient if I have the Woodstock heat shield for the pipe?
I have 12 1/4" between the joists I am wanting to install between and will either go with 9438A 11" Ceiling support box or 9436B Reduced clearance ceiling box. I can figure that out when I find the clearances for these two components.
Here's what I need help on:
What will I need to attach the double wall to the ceiling support? There's a finishing collar they've got, an adapter--what would do the trick? Do I need both?
I'll run Class A galvanized inside the house and switch to stainless after I get up towards the roof. I am not sure what I need to install properly through the roof. I'll need the adjustable flashing, the storm collar, the cap, and maybe the support strap if the chimney height warrants it. But do I need the roof radiation shield 9489 and/or the roof support 9463? The catalog makes me think that the roof support performs the same function as the ceiling support I'd be using down below.
Thanks.
Thanks.
