I looked at a interior masonry chimney today that is 105 year old construction. It has no clay liners whatsoever. The owners have had a hearthstone freestanding rear vent stove installed in the opening with a uninsulated stainless liner up to the top. I am extremely doubtful due to the age of construction that there is 2" of clearance to combustibles the length of the chimney. The smoke shelf/damper area was busted out to accommodate the install and there was plenty of creosote present in and around the smoke chamber area some of it being honeycombed chunks indicative of a past chimney fire.
Also there is appliance clearance issues. The worst being the stove calling for 36"s of clearance off the top and the existing mantle is about 24"'s away. Also the t at the back of the stove has the liner over top of it. Instead of going inside(male end down).
I would be curious of some thoughts on this.
1. What would you recommend to correct these issues?
2. If you are in the industry would you even clean a system like this and just note deficiencies. Or walk away until corrected?
3. I constantly see uninsulated liners installed into masonry chimneys, most are clay lined. Is it commonplace in other areas to install/see uninsulated liners installed in masonry chimneys? I saw the receipt today stating that this install was all to code. But it's not IMO.
I didn't clean it as is.
![Unlined masonry chimney install? Unlined masonry chimney install?](https://www.hearth.com/talk/data/attachments/188/188039-03091343442c363303c1903b3866179d.jpg)
![Unlined masonry chimney install? Unlined masonry chimney install?](https://www.hearth.com/talk/data/attachments/188/188038-13c2d864478fa48e8e11ee5d34b06006.jpg)
