It's on a need to know basis & he doesn't need to know!It's a secret check your manual
under draft adjustment . Sheee
don't tell anyone
Here is my manual. I am not seeing anything about it or how to adjust it correctly.
http://www.lopistoves.com/TravisDocs/93508108.pdf
Mlampert40, the overall design of your Lopi Yankee appears to be somewhat inspired by the old Whitfields of the 80's and 90's.
On Whitfield stoves with the touch pad control we have three trimpots similar to the one on yours.
The function of these trimpots are described in the manual for my Quest Plus:
Locations of the trimpots:
View attachment 222353View attachment 222354
The convection blower trimpot on the backside is particularly interesting. Note this sentence concerning the convection fan trim:
"This can be used to eliminate fan noise by trimming fan speed slightly above or below a noise band."
Electronically the control of the motors is done by triacs switching the ac sinewave very precisely at certain angles of both the positive and negative halfwaves.
The #3 setting is the one I use the most on my stove and in the first months with my stove, I was annoyed by a horrible whining noise from the room blower at this setting. I even hooked up a handheld oscilloscope to the blower voltage to check if everything was perfectly symmetrical. On this video of the set up you can hear the awful whining sound climaxing at the #3 setting.
All it took to eliminate this was tweeking the trimpot slightly
Also note the rather violent damped oscillations that occur immediately after the triacs cut the halfwaves to the inductive load. To ensure safe triac operation here, an RC snubber circuit has to be present on the circuit board.
RC snubber circuit, technical background:
The whining noise is most noticeable at the 1:08 time mark:
