Hoping I'm not asking a repeat question, I've found a couple posts similar to what I'm about to ask, but not the exact application, (for instance https://www.hearth.com/talk/threads/kozy-heat-z42-heat-duct-effectiveness.20869/) Sorry for the long start, just want to provide as much detail as possible based on my scenario, I'm sort of stuck in fireplace replacement limbo and I'm holding out that someone on the forum might have been in a similar situation.
I have a old builder grade wood buring unit from 1980 (year house was built.) We heat mainly with propane and enjoy the current fireplace for ambiance. I can get free maple and oak, I just have to go out and cut and chop, if I'm too lazy I can get it from a neighbor for almost free. That said the condition of the unit and chimney are starting to fail(36 years old.) I'm sure most of you could guess based off the year of the unit, but the current unit could be better labeled as a AC unit vs. a heating appliance. All considered I'd like to replace the unit and start new, unfortunately I'm running into numerous issues. Mainly is location and sizing, we have a 1500 sqft ranch house. The fireplace is in the family room, the family room is located on one corner of the house and is not central. I would like to buy an epa efficient fireplace since an efficient fireplace seems to run very similar to the less efficient models, but at the same time I would 1) Like to move some of the heat to other rooms since I'm spending money to have a new unit put in. and 2) Even with moving heat, not turn the room with the fireplace into a sauna (or worse.)
I have looked at multiple units that have heat venting duct options, Kozy, RSF, etc. What I'm curious about is, does anyone have any experience with how much of a dent in the overall heat output in the room with the fireplace does the additional ducting and heat draw make? The room the fireplace would be in is a 225sqft room(12.5x18 with a 8x4 bay window.) the room has a 5'x8' exit into a 48sqft mud room. from there its a 3'x8' opening into the kitchen and the rest of the house. Even running a ceiling fan on reverse, box fan inot the room, and just the fan on the furnace, i suspect that won't be enough to move the large amount of possible heat created. Ducting kits with fans that are optional with some of the units kits (970 on kozy and central fan on the rsf) seem like a no brainer to make sure heat gets to other parts of the house, but its left me wondering if that will be enough to keep temps below 90 in the family room... Also, most of the venting runs would be horizontal, not vertical, while the manuals I've read claim the blowers can even go in a downward direction, I'm curious if any has found this to cut into performance.
So I'm lucky enough to occasionally drink beer with a HVAC guy, I've bounced this off him and he was going to do some research to see if there was anything else we could potentially do, but admitted that fireplace heating isn't his specialty.
So if anyone has had a similar experience or setup, I'd love to hear back on what worked what didn't, if not thanks for taking the time to read! Worse case I either do nothing and we stop burning or I look at a less efficient unit with out the venting options.
