Good day all
I am not usually one for forums however I am at a loss, need to desperately diversify in my heating source, and no one I've spoken with seem competent. So in efforts to do my homework prior to a large, permanent purchase, I am here.
We have a 2000 sq ft home and a 1200 sq ft basement that we've made a main part of the house for home theater, exercise, play etc. The upper floors are currently heated from a hydro-air central heating system fueled by propane and the basement is not heated.
We are getting SLAUGHTERED in propane costs and desperately need to do something alternative. When looking into a wood stove option we have not gotten competent responses to our situation.
Our basement ceiling has spray foam insulation which works amazing but in this situation works against us. MY MAIN QUESTION is if we put a sized wood stove in the basement how are we going to get the heat dispersed through the entire home. I tested out the ceiling with a 65,000 btu propane heater in the basement on a cold winter day and got ZERO heat transfer through the floor. Some have spoke about leaving the basement door open, cutting even more vents in the floor (not appealing to me) or cycling the air handler fan to disperse. My hesitation is these are options and no one seems to have had the same situation and know what will work for sure and I'd rather not make such a sizable purchase and permanent installation if I am not 100% positive.
THANK YOU ALL IN ADVANCE
SERIOUSLY THANK YOU, 750+ / mo for propane is horrific
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
