Can someone confirm that I understand the controls, and/or correct where I am wrong. Currently working all on manual.
As I understand it:
a. There are basically only 3 things to adjust: Convection Fan, Combustion Fan, and Pellet Feed (assuming the slider/damper setting is good).
and then is it
b. Changing the Heat Level setting 1-5 changes all three of these (at the same proportion), given that the combustion and pellet feeds can be float as a plus up or minus down if you adjust them accordingly. (And the only way to change the convection fan rate is with the heat level setting.)
or is it
c. Changing the Heat Level setting 1-5 only adjusts the convection fan rate, and the combustion and pellet feed is set independently with their controls.
As I understand it:
and then is it
or is it
