I'm completely racking my brain on what to go with here - which seems like that’s a common thing when making a hearth decision. So, I’m back and looking for advice.
We are now wanting to put a stove on the main level of our ranch.
The question is... WHAT WOULD YOU DO? Seriously - if this were your home how would you go about replacing the existing fireplace with an actual heat source? I’m kind of starting over - so looking for any and ALL suggestions. I've included some pics of the current setup below.
Here’s what we’ve got and things to know:
• Roughly 5000 sq ft open floor plan ranch (first floor = 2800 sq ft)
• Well insulated with 10’ vaulted ceilings in great room (which is where the fireplace is)
• Current opening dimensions: 36” w X 29” h X 24 1/2” d (at base) 21” d at top of arch (brick is angled toward the top of arch)
• Chimney Height: 15’ from crown to fireplace floor
• Reliability is definitely important (I don’t want something that is known to have problems)
• I’d really like to have the option of having a fire when the electric is out
• Looking for something that’s quiet (fairly close to the tv)
• We want a good heat source main living area(s) - but we aren't looking to heat the whole house with this
Other considerations:
• Large glass (we want to see the fire as much as possible)
• Don't want so much heat that we can’t sit close to the fire (couch will be roughly 5’ away from the hearth)
• Looks are important (not wanting something that looks like an antique - or too modern)
• Would really like a surround that will match the arch in the stone. Of course we’d be looking at having one made. Not sure which inserts (if that’s what we go with) have “removable” surrounds?
Given all of this… what would you do?
Really looking forward to hearing all of your suggestions. Thanks in advance!!
![*Ugh - Starting Over - What Would You Do? *Ugh - Starting Over - What Would You Do?](https://www.hearth.com/talk/data/attachments/266/266713-f0b29a7cf1957a58f5eaf096431c0a21.jpg)
![*Ugh - Starting Over - What Would You Do? *Ugh - Starting Over - What Would You Do?](https://www.hearth.com/talk/data/attachments/266/266714-09c5d548d90ae2b7261a0b866143b590.jpg)
![*Ugh - Starting Over - What Would You Do? *Ugh - Starting Over - What Would You Do?](https://www.hearth.com/talk/data/attachments/266/266715-ed124b6f55f7a8e98da2a85e556cdf1b.jpg)
![*Ugh - Starting Over - What Would You Do? *Ugh - Starting Over - What Would You Do?](https://www.hearth.com/talk/data/attachments/266/266716-91f644d021ccc7e7cad0b4fa16c94502.jpg)
