I have been using the search function here to research a lot of valuable info. This site has truly helped me out with my new stove. I don't want to add to the redundancy of the info, but I'm still in search of a few answers about my PDVC.
I travel weekly for work and tomorrow I will be leaving for 4 days. This means I'm leaving the stove and its operation in the hands of my dear wife. Not that she won't be able to handle the job, but I've been caring for the PDVC since I installed it and I REALLY like my stove. I have been cleaning the stove daily, which includes the items I've found here and info referenced by Englander:
- Empty burn tray and scrape off all buildup.
- Scrape off ash build up on sides of burn pot and around bottom auger tube.
- Use 1/8 drill bit for air holes.
- Finally I sweep all ashes in the burn pot, ash storage, and doors and finish with a window shine.
Good to go.
As for my wife, I don't expect her to do this daily. She simply doesn't have time in the morning to do this as I have. I'm planning on having her turn the stove off when she gets home from work and simply maintaining the burn tray/pot area. Removing clinker and ash in the tray. Does this sound good for the time I'm away? Any other tips to pass along for her?
As for cleaning question, I see that scraping the bottom auger has been mentioned here frequently. I'm not finding any buildup on my auger/tube. I can usually scrape a little buildup of the area surrounding the auger tube, but nothing inside or on the auger itself. Where should I focus my attention? Here's a picture of the stove following my cleaning this morning.
(broken image removed)
Next question concerns the "clinker". I just took 30 minutes to search and read the info available here. It seemed to be that many believe the clinker is a result of one of two things: low burn setting and pellet type. I have had to remove a clinker each day during cleaning. I roughly burn 1 bag per day and the clinker fills a good portion of the burn pot. Today I have been running on low setting all day (1-3) and there is no clinker for the first time, just ash in the tray. I'm confused as a result. Here's another pic:
Last question reverts back to my install. I've been meaning to ask this but have forgotten for the past week. I decided not to include the elbow at the end of my install for stability. My horizontal run ended up being too far from house to use the support bracket included. The pipe seems much more stable without using the elbow. As a result my smoke stack isn't installed as recommended. Should I install the elbow? My only concern would be an increase in smoke/soot on my vinyl siding. I don't want to hurt efficiency of my stove though. Here is the install:
Thanks again for any input. I can say that I'm officially a pellet pig. I love our freaking stove. Today (outside temp 27*F) is has maintained my addition and living/dining/kitchen area at 70*F while set to 1-3. My furnace has not run in hours!!
Good to go.
