Hello
Happy Halloween!
Well maybe my body is not used to this freezing cold weather yet. The Temp outside was 26 Deg F at 5:00 AM. The coldest temp of the night. It is a basement install in a split and it Does heat the whole house with No oil.
So I turned the pellet stove up to Heat Setting or Auger Feed Rate up to medium # 3 which is 3.22 lbs per hour! That is about 150 Deg F coming out of the registers in the living room and kitchen! Around 9 AM I turned it back down to 2 and turned the fan to pull the heat upstairs off because it was almost 75 in my Living Room Too hot!!
Is anyone else using 3 lbs/hr or more now?
Feed rates for the Avalon Astoria.
Heat      Burn
Setting  Rate (Lbs/Hour)
  1         1.7
  2         2.46
  3         3.22
  4         3.98
  5         4.74
  6         5.5
Happy Halloween!
Heat      Burn
  1         1.7
  2         2.46
  3         3.22
  4         3.98
  5         4.74
  6         5.5
