Ok so i finally got the time to try and fix the crack in my tank at the engine mount. I had it mig welded first but it still leaked. I fired up my stick welder on DC+ and used a 7018 rod to try and seal it. No good. Still leaks. Ground it down and went at it with a 6011 rod for more penetration and still have some pinholes. Seems like the oil residue is keeping the weld from making a good seal no matter how tall i build it up. It even cracked one weld while i was welding on the opposite side of the mount. So the fluid is vaporizing and keeping the weld from sealing off is all i can figure. Yes i did drain the oil. I also used thinner to dry up the oil on the outside of the metal. Do i just need to try some epoxy or try brazing it? I think ive slowed it down and just got two small holes now but it seems i just keep moving the leak every time i try to weld it. thanx
