Good evening all I am a newbie on the site and was wondering if someone could give me some information in regards to a brush attachment for my drill to clean the burn pot. Cannot find anywhere.
To maybe help you out we need some info of your stove. Most stove burn pots can be fine with a scrape or brushing with a simple arm powered wire brush. Needing to attack it with a powered brush may mean a larger more serious problem.
For scraping, i use a pry bar that I sharpen a little on the bench grinder. For the burn pot holes, I use a small round file. Personally I would not want a power attachment for this job as I want to know how deep I am so I don't damage the igniter or ream the holes to a larger diameter.
A pry bar works great, mine is 3/4 inches wide which allows me to clean the side as well.
Thanks for the tip. I burn newp, cannawicks, easy blaze, awf white pine, Corinth softwood, okanagan gold, mwp, and energy logs aka idaho woods. I am just looking for the easiest way to clean the burn pot. I have a wire detail brush and it's cheap.
Welcome to the forum JRA... I use a 1" putty knife and a scotch brite pad to get carbon off the stainless steel burn-pot. It lifts out pretty easy on mine. Once the pot is cooled down, I let it soak in water while I clean-up the rest of the burn chamber.
I think many new pellet burners think they are supposed to keep the inside of their stove "showroom new". Not-gonna-happen... Clean off any carbon buildup/glazing/clinkers, make sure all holes are clear and unobstructed, and then stop worrying about it.
"Clean" means ash and glazing removed, not back to bare metal. I've had to use a drill only once, when I left ashes in all summer and got the slightest bit of rust on the surface in a few spots (I know, very bad stove steward, but it was a rough spring that year). Anyway, you really shouldn't need a drill-powered brush in most cases.
