Jotul GF 300 DV - installed in seasonal use home, unit was not used for two years. This year cleaned and vacuumed main fire box burner plate, burner gas orifice, thermocouple, thermopile, pilot light assembly. The pilot light lit, stayed lit with good
flame length and color. Removed and cleaned everything in the fire box, logs, stones, and coaxial flow chimney top removed and inspected for intake and exhaust air blockages. I checked the exhaust outflow side of the coaxial flow pipe for obstructions by blowing air from a leaf blower up from the firebox (no back pressure of air) but could not think of a way to inspect or test the fresh air side for obstructions such as mice nests, wasp nests, etc. without removing a section of coaxial pipe above the fireplace unit.
When knob on gas valve was turned from PILOT to ON main burner would ignite and after 4-5 seconds there was a loud click heard and felt from the gas valve and both pilot light and main burner would extinguish. The pilot light could be relit and the main burner could be lit and then as before extinguish after 4-5 seconds. See 16 second long video.
If the front safety glass was removed the main burner would stay lit. The flame would be irregular and not all of the holes in the burner plate would have a flame.
This model Jotul has a rectangular plate on the top of the firebox that has two insulated holes that allow the plate to be held in position by two threaded posts on the left and right side of the plate. I have no idea as to what this rectangular plate is designed for, only that it was closed when the unit was previously working. I had removed and used this plate as a source of fresh air with the safety glass on the front of the fireplace installed while troubleshooting the problem.
Used a multimeter to check SIT820 resistance test between TP and TH - good test between 1.75 and 2.75 R
Checked resistance on main gas valve solenoid - good test between 0.0 - 0.2 R
Checked thermopile voltage with pilot light only lit at TH TP and TH terminals - good test about 750 mV
- With OFF/PILOT/ON knob turned to ON the mV doesn’t drop AT ALL and stays the same, about 750 mV, that is not what I expected and there was not a voltage drop. Bad test, but the gas valve opens and the burner ignites.
Some other thoughts -
The exhaust restrictor plate is wide open, could it have fallen from partially closed to fully open over the years? The restrictor plate is held in position by one screw that the plate hinges upon. The unit is free standing and has two 45 degree elbows in the axial flow pipe that connects the fireplace to the exterior of the home and the vertical run is about 12’. Using the chart the horizontal run is less than 5’ and the vertical run 12’ give a restrictor plate position C. I will need to check the device to see which setting or position the restrictor plate is set now.
![Troubleshooting Jotul GF 300 DV - Main burner and pilot light go out shortly after turning burner on Troubleshooting Jotul GF 300 DV - Main burner and pilot light go out shortly after turning burner on](https://www.hearth.com/talk/data/attachments/295/295276-45415420e76eb98737f08a2b39f6f720.jpg)
