Purchased a home built in 2002 with a Harman p68 pellet stove. Can't get it to auto-ignite. It goes through several ignition cycles for about 30 minutes before status light blinks 5 times indicating failed ignition. Feeling the burn pot afterwards it's warm but not so hot you can't touch it.
Here's what I've done so far:
Based on research, two thoughts I have are:
- Sweeped the chimney
- Vacuumed all the ash out of the stove. Made sure all the holes above the ignitor are clear, burn pot is clear.
- Pulled out the ignitor and cleaned all the ash in there. Tested the ohms on the ignitor and it was within spec. Despite this, ordered and installed a new ignitor just in case.
- Replaced the two gaskets on the door (one by the seal and one behind the glass).
- When I manually ignite the stove it seems to work well - at least as far as I know. I have experience with wood stoves but this is my first pellet stove.
- Air/draft issues - what do I need to do/check for here?
- Could there possibly be something wrong with the circuit board?
