Trouble with attaching vertical stove pipe to my house.
dansteelerfan
7
I've recently bought an Accentra Harman Pellet Stove.
The installation went pretty smoothly....except for one thing.
The vertical pipe (outside of the house) is 15 inches away from my siding. I am not aware if there is a product that I can use to attach the pipe to my house. I'd like for it look nice and of course be very secure.
In the mean time, I have used a thin flexible metal band that is typically used by plumbers to attach the pipe to my house. It looks pretty bad.
Can anyone help?
Welcome Dan. I would use the marlo extender. It is odd looking but is very solid. I am not sure if they can still be found, but I have seen them before. Good luck.
I had the same situation. In order to have no seams inside the thimble I had to use a 2' horizontal out the wall, which left me about about 12" from the siding.
What did was order an Duravent adjustable wall strap, the strap and the base are two separate pieces that are fastened using a bolt. I just cut a piece of aluminum bar to length for each side and drilled holes at either end to fasten to the strap and the base. took about ten minutes and it looks great.
I cut some pieces of the trex composite decking - and used three stacked together to bring out to the proper distance to attach the pellet pipe.
[Hearth.com] Trouble with attaching vertical stove pipe to my house.
this will put you in the ballpark i think (broken link removed)
i just looked around quick
Just go to your local hardware store and buy a piece of aluminum and make an extension yourself. Takes about ten minutes and you can be sure that you get the exact length that you need. You just need to have an adjustable wall strap to start with.
