Trouble after startup
MSimon
3
New York
I have a Quadra Fire 1200i. My control box started blinking orange which indicated the thermocoupler was bad. I changed that and now the stove won’t feed pellets after the initial startup. There is no light on in the control box (neither green or red). I moved the thermostat into position where it calls for start up. The pellets fall and ignite. No more pellets fall after that. I detached the vacuum hose and blew into it. There didn’t seem to be any obstruction. I also jumped the vacuum switch but nothing changed. The exhaust blower comes on at start up like normal. I clean my exhaust pipe regularly along with all other compartments. Not sure what I should do next. Thanks for any help
A friend has the exact same stove so I brought my control box over to his stove and swapped them out. My control box works perfectly in his stove. Trying to rule different things out.
Try changing the thermocouple wires around some were wired incorrectly. Don't go red to red and white to white, change the polarity.
