Hello, all. I'm in the midst of troubleshooting a water issue with the wood stove in my garage..
I have a Defender style 1200sq ft wood stove that has a single piece of single wall, to double wall up to the ceiling support box, then DuraPlus triple wall chimney pipe from there the rest of the way up. Installed back in October and have ran it periodically since then with zero issues until recently.
I've noticed that the one trim ring screw on the bottom of the support box had some rust and notice a small, quarter size, bit of surface rust on top of my wood stove. Just enough that it came off with a paper towel.
I dropped the trim ring down a hair and put a couple pieces of paper towel around the holes for a couple days and came back bone dry. This morning, after having some rain overnight, I did this again and still dry. So, I decided to twist up the paper towel and fish it up the holes from the trim ring. 3 of the holes are bone dry, but the hole from the rusted screw will saturate the paper towel then begin to drip.
This leads me to believe that the ceramic insulation inside is saturated. I'm curious though why it is only saturating on that specific side. Could this just happen to be where the condensation is building up or is it more likely a leak? Just seems quite odd that it's only wet in that specific area. The garage is insulated and drywalled, as well as being heated periodically by a mini split, so I'm assuming that the attic space is going to be quite cold compared to the rest of the garage.
I've inspected the roof, pipe, etc a few times and it all looks like it's sealed up tight. The only thing I can maybe think is that there's a rivet on the outside wall of the chimney pipe right above where the rain ring is mounted. Could this be a culprit for water intrusion?
Any insight would be appreciated. Thanks.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
![Triple Wall Chimney Pipe Leak/Condensation? Triple Wall Chimney Pipe Leak/Condensation?](https://www.hearth.com/talk/data/attachments/289/289446-617779657cb315dc6a92f868561de58c.jpg)
![Triple Wall Chimney Pipe Leak/Condensation? Triple Wall Chimney Pipe Leak/Condensation?](https://www.hearth.com/talk/data/attachments/289/289445-3b1ba23f88b9203ae26bcea82d87b35d.jpg)
