I installed two tridicator on supply and retunn of the boiler loop. Both gauges failed, one immediately then the other two weeks later. Fogged right up with moisture collecting. I capped the tees and waited to replace them untill changing the boiler. I finally changed the boiler and reinstalled two new gauges of a different brand, making VERY SURE gauge would not bottom out in the tee and to use a wrench on the stem to just snug and NOT twisting the gauge by the face. Only pipe dope no tape. Nothing. No temp change when the boiler fired up on either gauge. Airbound? Loosen the gauge and water right behind it so I take them back and put in two more. Two new ones work so I figure: Go figure?
I wake up this morning and one gauge is fogged up. WTF is going on here? At this point I know its me, but I can't tell what. The gauge is good from 250f and 60psi. I'm not using tape, only dope. I could see if the pressure/head faied because it fouled but what about the temp and fogging? At this point I'm thinking to abandon them and continue to use an infrared themometer.
