michaelthomas said:
I have my last row of wood that got pretty soaked when the tarp let loose in the past few storms.
I was gathering last week and the wood is like an ice chunk. It was near impossible to start the fire and I was worried about adding Icy wood to a hot stove. I am able to bring in 3 or 4 days worth of wood at a time with my wood wagon but even after having the wood in for 2 days with the fire going it is still damp. I am wondering if there is a trick to stack it on the driveway with a make shift greenhouse to increase the temp to thaw and dry it a bit. I do not have any dry wood left and have another month of heating here in Maine. Oil just went up to 3.56 a Gal
!! This wood has been stacked and split for over a year so it should dry out if I can get some heat to it. Any good ideas?[/quote]
Now you know why I hate tarps & think little of people that recommend them & have 3 woodsheds instead.
What flame said and what brooktrout said but I use a 24 inch box fan , usually on high,aimed first at the stove,to pick up the stove's heat & then in line with the standing on end wood.
A side effect of this is that the drying wood humidifies the room air.
Even with 3 wood sheds, some extra wood won't fit inside , as I just can't seem to stop picking up free wood whenever I see some & I over stock my storage capacity & always end up drying off some wet wood in march to burn 3 weeks later.
The longer you can wait for it 2 dry,the better it burns, but if you gettin cold,just go ahead & burn it, AS LONG AS YOU DON'T HAVE A CATALITIC COMBUSTOR. Cats won't abide wet wood,it ruins them.
ANOTHER TRICK is to mix a little wet wood in with a mostly dry load of wood. The dry wood will steam the water out of the wet wood but you will loose 100 or 200 degrees of the fire while the wet wood is outsteaming as the steam cools the fire.
When the wet wood finishes steaming out, it will burn as dry wood & fire temps will go up a couple hundred degrees, so watch the stove for this as your primary air will be set high because of the wet wood & will give too much primary air for when the wet wood becomes dry wood. a overfire condition could result if you are not right there to cut down on primary air.
WORD TO THE WISE.
