Robbie said:
BrotherBart said:And of course if that log happens to be standing straight up in the air and you want to know its length then we go back to the Boy Scout days.
Take a pencil or or any old staight piece of anything, and back up until you have the pencil tip at the top of the tree and the eraser at the bottom of the tree in your view. Then hold the eraser end even with the bottom of the tree and rotate the pencil to level with the ground. Then proceed to that point on the ground and measure the distance back to the tree.
Viola! The length of the log that you are going to cut down.
stoz said:Yes I am looking for a standing tree estimate of cords of firewood, I know I have seen it but can't find it.
Scott
JayY said:The US forest service published a table you could use based on DBH (diameter at breast height) and log length to 4" inside bark diameter. It is better than nothing. I have pasted it below. Hopefully it stays formatted. I found it online somewhere.
Tree Volume Table Commonly Used to Estimate Cords Per Tree.
Code:Height in Number of 8-Foot Bolts dbh (in.) 1 2 3 4 5 6 7 8 Volume in Cords/Tree 6 0.02 0.03 0.04 0.06 8 0.03 0.05 0.07 0.09 0.12 0.14 10 0.05 0.07 0.10 0.13 0.17 0.20 0.24 0.27 12 0.07 0.10 0.14 0.18 0.22 0.27 0.32 0.36 14 0.10 0.13 0.18 0.23 0.29 0.35 0.42 0.47 16 0.12 0.17 0.22 0.29 0.36 0.44 0.52 0.59 18 0.15 0.20 0.27 0.35 0.44 0.53 0.63 0.72 20 0.18 0.25 0.32 0.42 0.52 0.63 0.76 0.85 22 0.22 0.29 0.38 0.49 0.61 0.74 0.88 1.00
Note: Utilization standards: Volume is stem volume above 1-foot stump in standard, unpeeled cords. The standard cord is 4 x 4 x 8 feet. Height is number of 8-foot bolts to a variable top diameter not less than 4 inches inside bark. Applicable to all species except cedar. Source: U.S. Forest Service, North Central Forest Experiment Station.
Edit Bah! The formatting stinks. I did a google search and here it is on Univ. of Maryland website
(broken link removed to http://www.agnr.umd.edu/MCE/Publications/Publication.cfm?ID=77)
