What is the best way to care for a wooden handle? Shovels,wheelbarrow , etc are not looking good and getting rough. Is there something to 'treat' them with?
Ja, same thing here, only different. I have left over Danish Oil that has turned to gel and I reconstitute it with turpentine. No longer suitable for cabinetmaking but good enough for the wife.Danno77 said:(I usually have a bunch of Tung around for other woodworking purposes, that's why it get's used)
Hang them out to dry on a wire fence. Do NOT bunch them up and put them in a container.blel said:I agree with the above post about boiled linseed oil. It's relatively cheap and does as good a job, if not better than the other advertised products. Very simple and easy to use.
Danno77 said:I just wanted to be one more guy to say BLO. I also use Tung oil at times, but BLO for this purpose (I usually have a bunch of Tung around for other woodworking purposes, that's why it get's used)
Also, there is a train of thought around the "Old House Web" forum that you should do a 50/50 BLO and Turpentine Mix. It makes the mixture soak in better, dry faster, and be toxic to anything that might eat away at the wood and BLO (fungus). But that might not be a big deal if the thing isn't left outside much.
We're talking about maintaining tools (as in not buying new ones), not polishing.kenny chaos said:You guys aren't working hard enough if you got time to polish your tools.
That's a good thing. Working smarter, not harder. Laziness, (not necessity) is the mother of invention.kenny chaos said:You guys aren't working hard...
Sisu said:Ditto on the boiled linseed oil. Cut it about 50/50 with turpentine to accelerate drying. Dip some fine steel wool in the mixture and rub it in the handles.
