Refurbished Travis Lopi Pioneer Bay PI (Heritage Bay PI)
Keep warm in this cold weather! This all American wood pellet stove is one of the most reliable pellet stoves on the market and is in great shape! The control panel has easy to use knob controls and you can easily attach a T-Stat for automatic operation! At 28.7k BTUs it will heat 1,600 sqft. It has a upgraded exhaust blower and a new convection blower. The stove was professionally cleaned and lubricated.
Call Don - 603-553-7402 in Salem NH -- See pics below:
This is for Local Pickup or Local Delivery for $75
Brand new this stove is $2995.00
See specs > http://www.woodpellets.com/stovefinder/stoveDetails.aspx?appid=61
The Pioneer Bay’s easy-access ash pan and ash dump makes clean-up simple, and the door swings open when needed for firebox access. It’s no wonder more people look to Lopi for the ultimate in beauty, efficiency, and trouble-free home heating.
Lopi Pioneer Pellet Stove
The Pioneer Bay’s attractive cast brick fireback highlights the splendor of the fire while maximizing heat transfer to the room. A remarkably quiet, yet powerful 130 CFM fan helps distribute heat evenly throughout your home. Just fill the hopper with pellets, set the feed rate and push the start button. Nothing could be easier!The Pioneer Bay’s easy-access ash pan and ash dump makes clean-up simple, and the door swings open when needed for firebox access. It’s no wonder more people look to Lopi for the ultimate in beauty, efficiency, and trouble-free home heating.
Specifications
Model: | Pioneer | ||||
Fuel: | Pellets | Thermostat: | Optional | ||
Capacity: | 1600 sq. ft. | Efficiency: | 75% | ||
Max BTU: | 28700 | Hopper Size | 35 pounds | ||
Type: | Wood Pellet Stove | Width: | See Picture | ||
Style: | Traditional | Height: | See Picture | ||
Construction: | Steel | Depth: | See Picture | ||
Ignition Type: | Automatic | Weight: | 180 lbs | ||
Colors: | black |
Features:
Capacity Hopper 35 Lbs
Fueling your pellet stove or insert has never been easier. The top of the insert lifts up to allow access to the hopper. When full, your pellet appliance will provide you with many hours of uninterrupted heating.Easy Access
All Lopi pellet appliances are designed for easy maintenance. The swing-out door allows quick access to the firebox for cleaning and yearly maintenanceAutomatic Operation
Operate your pellet appliance automatically. Add a wall thermostat or remote control thermostat for the ultimate in hands-free operation. You simply set the thermostat to the desired temperature and the pellet stove will do the rest. The wall thermostat is standard on all Yankee models. If you choose to operate your pellet appliance manually, simply set the feed rates and push the start button to activate the auto igniter. Within minutes your pellet appliance is in full operation.
