I searched for a post covering my situation and could not find one. If I missed it, I apologize.
I need advice on the following:
I want to put a wood stove in my basement, run the vent through a centrally located masonry chimney, and exit through a metal roof. Length of run is about 30’. I know to use a SS liner, stove pipe from the stove to the liner, and the basics of what is needed to go through the roof.
There is a catch, of course. The existing masonry chimney was dismantled to below the roof line due to deterioration when the roof was replaced.
So how do I drop the liner down the chimney and secure it to the solid pipe for the through the roof connection?
Also, assuming the SS liner will be effectively hung from the solid pipe, will a couple feet of exposed liner be a hazard? There would be at least 12” of clearance from anything combustible.
A couple ideas I had -
Take the chimney down a bit more and make it even at the top. Then place a top plate on it to hold the liner, and connect the rigid chimney pipe to it there.
Flex liner goes all the way to the roof and mates with the chimney pipe there. Just not certain how to do either.
All advice is appreciated. Thanks!
![[Hearth.com] Transition from liner to class A at the anchor plate [Hearth.com] Transition from liner to class A at the anchor plate](https://www.hearth.com/talk/data/attachments/317/317030-1b46303f157ef45b773f48f359ec1aac.jpg?hash=tGMSyN3xqx)
![[Hearth.com] Transition from liner to class A at the anchor plate [Hearth.com] Transition from liner to class A at the anchor plate](https://www.hearth.com/talk/data/attachments/317/317031-94808b0aeadeb7782b9d4f60f1c975bf.jpg?hash=XvhVlI7QOK)
![[Hearth.com] Transition from liner to class A at the anchor plate [Hearth.com] Transition from liner to class A at the anchor plate](https://www.hearth.com/talk/data/attachments/317/317032-2d53a61233ffc447f7005b27dce6174f.jpg?hash=HDNPpjY-cZ)
