Do you think those hinges will hold up to the weight and wear/tear from loading an ATV? I would have probably welded on some hinges like these http://t1.gstatic.com/images?q=tbn:ANd9GcRfOnV-46BMNAANxQONWe_eg_eRK5jj2B79U1zAt2wL16a7kkhH... though I generally use steel over wood.
Great work and ideas Dave.. You can always pattern steel/diamond plate if want to later on if needed..
Ray
Looks great Dave, that will make that trailer alot more useful.
I tend to improve or build things myself with lumber since I dont have a welder either, thinking about some side racks for the new wood truck I picked up last month.
Todd
Hi DaveThought about some 1/4" aluminum diamond plate for the center (used section) of the tailgate/ramp.
Can cut it with a carbide blade & WD 40. Need to check the price $ .
Might be slippery, but stronger than 1/2" CDX.
If I got into welding , it would be mostly aluminum.
Light weight & easier on the back
Gotta figure out where to mount the spare tire next.
Thinking front & center
Hi Dave
I'v been thinking about hanging mine under the trailer,mabey with a tire winch from a P/U.My pickup has the same wheels so i'v allways got a spare in the truck,so it would only be used by someone that borrowed the trailer,or if i was having a bad tire day.I have good luck with tires,so two spares are overkill but nice.
Thomas
It would be nice if the truck tire is the same.
Never tried my PU jack to see if it would jack the trailer.
Figured , at worst, off load & block the back & use the tongue jack.
My trailer is pretty low so under it not a good option.
Side, front or keep it in the trailer & throw it in PU when loading.
I'm confused. In your ATV test photo, it appears that you're using store-bought metal loading ramps over the homemade ramp. Why not just use the store-bought, if you have them? I'm obviously missing something...
I think I have a good sized piece of diamond plate aluminum that I don't have any plans on needing. I'll check tomorrow if I'm in that corner of the shed. If you call for prices make sure your sitting down. Figure about $10-15/sq foot for 1/8".... yes as in $400 area for a sheet.
If your truck has a sizzor jack it should have no problem getting under the trailer axle and lifting it...bottle jack could be too tall. If you had a cord of wood and and ATV on there it would lift one side of one axle enough to change the tire.
As for the spare, either mount that on the tongue as pictured or on the outside of the side rail in front of the wheel wells.
Imagine what an OSHA certified woodcutter, him, his PU & his trailer would look like. (no room for wood)
Probably the less $$ route.It would probably look more like a guy sitting on a couch cranking up the T-stat.
