Got an email that TSC, at least in our area has their annual Demo Days this coming weekend. Actually, Saturday, April 21 to be exact. Might be a good time for some to try out their splitters or mowers, etc.
HUSKEE 22 ton splitters on sale today, Friday and Saturday for $999 !!
Mount Pocono PA store has 2 left. (after I brought one home)
I'm another one who could split so much faster with my maul and would never think of using a splitter. Well, at 53 1/2 my splitting the hard way is over.
I think I'm done with Tractor Supply. I just spent $70 on a new blower housing, dipstick tube, and muffler bolts for the rattled apart POS Briggs on my Huskee splitter. I got the parts from the dealer where I just bought a new Gravely mower. They do service and warranty work for nine TSC's in the area. They're always busy.
My new one came with a color insert in the manual showing how to make sure the coupler is straight between the motor PTO shaft and pump. I know misalignment was the vibration cause. Mine doesn't shake or vibrate.
It is mounted straight when new. I checked the three in stock, pulled the engines over, and they were all lined up correctly. The pump is mounted with bolts and lock nuts. I assume if it's overloaded the pump could move, so it should be checked from time to time.
The instructions also advise to check tightness of set screw on motor and pump shafts. The coupler is similar to the coupling on an oil burner pump with ears that lock into each other.
I was just at TSC, and the only thing that addendum covers is the assembly of the lovejoy. They apparently weren't put together correctly and work themselves apart. Not sure what vertical alignment would have to do with the problem I have. The advice I got was to call Speeco, since I didn't purchase the service plan.
