But doesn't a Bobcat ( and similar) skid-steer machine use hydraulics? Those produce a lot of "traction" and have decent amount of weight.I would be concerned that the Zero turn running gear won't be robust enough for reliability. They really aren't designed as a traction engine drive train like what you are dealing with....
Even the smallest hyd system in the smallest bobcat would whup on any mower system.But doesn't a Bobcat ( and similar) skid-steer machine use hydraulics? Those produce a lot of "traction" and have decent amount of weight.
Agree that a system from a Z mower may not be enough though.
Exactly what I mean.Even the smallest hyd system in the smallest bobcat would whup on any mower system.
WOW -that is really cool. I work in Lapeer often and would love to see in action sometime.
Do you have a specific system in mind? Make/model of drivetrain? If you did, you could probably pull up specs to see what kind of torque you are dealing with. If I remember correctly (and that is not guaranteed), I think the gas converted to hydraulic is accepted as a 20% loss.
