Touch The Stove!
stonehouse
So I have one of those freebreeze fans. Mine needs a shim. So I go to change the position of it. I had one glove on. Picked up the fan with my left hand, the shim with my right. Repositioned the fan, transfered the shim to my left hand and burned my thumb and middle finger real bad. Second degree burns. Luckily the shim landed on the stone coffee table and not the sofa or something.
Be careful when you touch the stove!
Ouch! I feel for ya. I had a senior moment one night moving a thermometer from one stove to another. Picked it up off of a 500 degree stove with the gloved hand and promptly tossed it in the palm of the un-gloved hand.
It's just not fire season until you get burned!
Aloe plant is what I keep handy......... :)
I usually have to use it a couple times a season..........works very fast and you can put it under a band aid to keep it from hurting like most burns do.
(broken link removed to http://herbalcollective.ca/aloe.html)
Robbie
I bet your gonna buy a second thermo now. Or maybe not! The extra 15 Bucks will probably hurt ya more ya cheap skin flint.. %-P
I have quickly learned that putting both gloves on is worth it (as I sit here with a burn on my pinky knuckle)
.......See, you guys should have read your owner's manuals! It tells you in there, that the stove is hot while in use.....:lol:
I think mine had a warning lable on it when I bought it but it burned off since ;-)
Just picturing that I need a keyboard
I go through those things like popcorn around here. If more people knew how inaccurate half of them are it would scare the crap out of them.
Maybe I just buy a Blaze King. I hear it calls 911 if it gets too hot or your cell phone if it is running low on wood a couple of weeks after loading.
The stove manufacturers need to add designs were we get burnt. That way you could tell the real wood burners as we would be branded.
Don
