top vent for a xxv
rdubs20
185
Northern NY
Can I install a harman xxv with the top vent adapter through a regular wall or does it have to go into a masonry chimney? I would like to use that to make it look more like an old wood stove. If I can, do you run a pellet stove pipe or liner inside the 6 inch chimney pipe?
Here is the install Manual for the XXV. Refer to venting configuration #4.
  • XXV.pdf
so it looks like I could run either...which is cheaper or would you recommend?
Yes you can as long as the wall pass through is class a
