Just lit my first top down fire. What a different experience. Gas tubes start firing way quicker, stack heats up way faster. So the draw starts super fast. I was able to start cutting the air in about half the time. I recommend.
Nice! It’s most definitely the way to go. I even can’t help myself but to use it on all fires I build lol. Everyone thinks it’s crazy till they see it in action.Just lit my first top down fire. What a different experience. Gas tubes start firing way quicker, stack heats up way faster. So the draw starts super fast. I was able to start cutting the air in about half the time. I recommend.
Took me awhile to catch on to that too even though I read a lot of threads about it. Sometimes it's hard to get us old geezers from changing our ways.Just lit my first top down fire. What a different experience. Gas tubes start firing way quicker, stack heats up way faster. So the draw starts super fast. I was able to start cutting the air in about half the time. I recommend.
Its basically the exact opposite of starting from the bottom up. except all your wood is loaded which is also a great benefit that I forgot to mention. Splits on bottom and smaller pieces as you go up until you get to kindling. I couldn't get it to work last year at all but it was 100% because my wood was not seasoned enough. I load my first load on a cold stove north south bottom layer and east west next layer alternating as I go up. After that on a reload I just put stuff in. I hope everyone is having a great nightI've tried it, but didn't get it working well. Anyone care to explain the trick to it?
It's funny I almost always do top down fires in the stove, but almost never do in firepits. I enjoy the process of building up from smaller twigs to larger logs and splits when around a firepit.First top down fire I tried so very long ago did not work very well . . . I think the second or third one also did not work very well . . . but once I figured it out . . . well, it's all I use.
Funny thing is when I go camping and do a top down fire my friends often think I have lost my mind . . . I forget that most folks camping do not do top down fires.
I posted this on another Thread, but here is how i do it.I've tried it, but didn't get it working well. Anyone care to explain the trick to it?
Just do it backwards. Big stuff on the bottom smaller as you go up. I find it just as enjoyable. The whole teepee fire probably isn’t a good one for top doe unless it’s it’s really big.It's funny I almost always do top down fires in the stove, but almost never do in firepits. I enjoy the process of building up from smaller twigs to larger logs and splits when around a firepit.
Any time I had problems my kindling was too big and I didn’t have enough of it. Only 1/3 of my fuel load by volume is full-sized splits. Everything else is kindling of nothing bigger than 1.5” squareI've tried it, but didn't get it working well. Anyone care to explain the trick to it?
i see what you’re saying, but that’s not for me. I like to start with twigs and small kindling. Then progressively work my way up. It’s cathartic. By the day I’m burning giant logs.Just do it backwards. Big stuff on the bottom smaller as you go up. I find it just as enjoyable. The whole teepee fire probably isn’t a good one for top doe unless it’s it’s really big.
Well i set this one up for a longer burn and slow start up on purpose. I was going for a single long burn. If you want it to start faster, switch the middle row for smaller pieces. Also open up the gap between the splits for coals to drop down much faster. I mentioned this in the later parts of the video. I'll make a faster starting Top Down video soon. You certainly can use firestarter and fat wood, super cedar, etc and it will work very well too.While I appreciated the video the old fashioned way would have been burning already, in the king it's seldom over 20 minutes before she kicks off and you can close the bypass. I never use kindling only a fire starter 99% of time 1/2 super cedar.
Yeah it really depends on the stove design. Not all cat stoves are the same. I think some cat stoves like Blaze King have the cat in the upper part of the stove so the smoke still exits from the top. That is not the case with VC stoves which are a sort of "down draft" design and really need a good coal bed to work as intended.So my stove is a Non Cat, and the Top Down works so well because its heating up the secondaries immediately, and establishing draft fast. In a Cat stove not sure if guys are getting better start ups or not?
