2009 Englander PDVC, not sure if my control board is working. when i adjust the heat range the top auger doesn't change it's cycle?
it should right? it's about 16-17 seconds b/w auger spins. i'm sure someone has sat there w/ a stopwatch and done this. what should i be getting b/w cycles as i
bump the heat range up?
or is the cycle always the same and then auger just spins longer each time? hmmmm basically i'm talking to myself so hopefully someone can help me before i drive my wife crazy
