I am new in the forum and I have a concern that maybe is easy to solve. I have a Osburn 2200 installed 2 years ago, and maybe because it was not properly installed or for another reason, I am having too much draft and cold air coming from the fireplace when the fire is off, that can blow out a candle.
I do not have insulation around the insert, neither around the liner (25 feet long), so that could be the main cause. But is also coming from the bottom of the fireplace insert (where the fan is located)
What could be the cause of these draft, that makes also difficult to start the fire, having too much smoke in the room every time.
How could I add some insulation around the insert without having to move it out of the fireplace (risk for the liner too), I guess it could be removing the faceplate (any ideas of how?)
Thank you for your suggestions,
Eugene
Eugene
