I must use 3 right angle bends in the 6" exhaust pipe to install an Englander NC-13 stove. The total length is 20-25'. Is this too many? What problems, if any, could i run into?
I'm taking a wild guess when I say this but I'm assuming that the 1st 90 comes off the collar, 2nd 90 to make it through the wall and the 3rd 90 is out the clean out then straight up to the cap?
Please keep in mind that single wall pipe needs 18" minimum from any combustibles unless shielded with an approved shield.
Is it possible to move the stove to a better location? or run your chimney straight up through the house?
Creosote accumulation.Any problems other than potential draft difficulties?
You may not have difficulties, the NC30 is a fairly light breather but with flue height you still might make the minimum height recommend by englander.
Figure 1 90deg bend is like taking away 3 ft of straight flue.
So the 3 bends is almost equal to 9ft.
22ft - 9ft = 13ft which is 2ft shorter than the recommended 15ft.
I’ve seen people run 12ft chimnies with this stove and not have issues.
You have to be mindful that dry wood is a must, and you will have to watch for build up as that will hurt your performance the most.
The minimum airflow settings in the NC30 might make for an exciting learning curve if you're only burning pallet wood. Read up before you start.
To answer the question its yes and no at the same time. Adequate draft is measured in .05 to .07 inches in water column. its unknown with the additional bends in the pipe if your going to have a problem due to the fact that you may naturally be in a high pressure environment.
What is known is that draft is reduced or hindered with 90 deg bends, so having less is always optimal. (that's why BG suggested trading any 90 deg bend with a 45 deg, it creates less turbulence with the smoke / air)
The other issue is longer flue runs with less than ideal draft, its a double edge sword to speak of, the chimney is the engine that drives the stove, so if the draft isn't strong the stove isn't going to burn correctly or as hot, if the stove isn't burning as hot then the flue gases will be cooler allowing for them to possibly condense and form creosote in the pipe, the creosote could then further restrict draft causing more hard ship.
The other possibility is that you have a reduced draft and every time you open the door to load wood you get smoke that escapes, or you have sluggish start up that are very smoky in nature, both are not ideal.
Cleaning becomes a little tougher because more than likely you will need to totally disassemble your black pipe to make sure the 90 deg bends aren't built up.
Word of caution, I am what is called an enthusiast, I am not a certified professional (there are some on here) these just some things I picked up while on this journey.
Pallet wood has a tendency to “take off” and go nuclear because it’s dried wood, offers lots of surface area.Jetsam, please elaborate. What do you mean by "exciting learning curve" with pallet wood?
There is a learning curve when burning it. When you first start to use it start off with small loads and gradually increase it.
Lol - don’t do that, sticking boards together to make a long flat surface = bad, have you ever had a bonfire where you dumped a full pallet on the pit? Lots of flames and heat all at once. Just image that energy in a metal box, there’s nothing wrong with burning pallet wood or mill cut offs, it’s just a different nature of the beast once it lites off, start small and steadyI intend to stack the flat pallet wood pieces close together so as to slow down the burn and add the thicker pieces to maintain the fire. I'll be sure to start with small loads. Thanks again, kennyp.
