The poor burning characteristics were that I was getting a black build up on one side of the stove and noticed the flames, when their were visible flames, like to be on that same side so realized there was an air leak. After examining the plates there was actually a difference in the in air gap from side to side, e.g. left side would have an opening of 1/2" and right side was open 3/4" when they should be uniform, as well as the plate on the right wasn't making contact with the metal stove bottom any more. I guess that metal rod just starts to sag a little over time with repeated heating and cooling.
There's not really many places where air can leak into the stove. Door gasket, ash pan gasket (evidenced by glowing coals over the ash dump,) bay window gaskets (not likely to be a major leak there, I wouldn't think,)...and the air intake plates, which are fixable. I don't see that 1/4" plate-steel rod sagging...there's not much heat there, under the air intake channel. There was a slight difference in the plates on the two sides, but only like 1/16", not the 1/4" you are talking about.
I picked up the BK Ultra for $2k....I loved the 91 but my work days are sometimes 14 hours and it stinks coming home to a cool house and barely enough coals to get a fire going again so I needed something that put out more heat for a longer time period. The only way the 91 could keep up with the heat I needed was to reload every 6 hours.
Nice deal on the King, even if you had to drive to get it.
![Cool :cool: :cool:](/talk/styles/default/xenforo/smileys/shade_smile.gif)
Wow, your house must be big, or maybe it's like my MIL's...plaster walls with no insulation, stove at one end of the layout, 9.5' ceilings, three walls of glass in the stove room, etc. Still, I was able to keep the house in the mid 60s in the back, to the upper 60s in the front rooms with 12-hr. burns in the 91. Stove temp measured on the front was still around 250 when I came to re-load. This was with good hardwood like Oak and hard Maple. Hickory and BL would extend the useful burn a bit longer. What kind of wood are you burning? If you are having to burn a load in 6 hrs. to get the heat you need, an additional stove or a wood furnace may be the only answer. I don't think the King will throw the raw heat of the 91 on a per-hour basis but maybe the 4 cu.ft. box will help keep house temp up at the end of the burn...I measured the 91 at about 3 cu.ft. usable space. Sounds like your house loses heat fast once the stove output drops off. I guess there's no one that can stoke the stove when you are working those 14-hr. days?
I used to burn a few medium-small "sacrificial splits" to get the stove temp in the 91 back up,
then load up. That way I could get the cat lit and the stove cruising pretty quickly without burning up too much of the main load.
the other day mine was really hot. Even with the air all the way shut down, it was still cranking pretty good (like around 1500). If it gets too hot, should I just open the bypass and try and cool it off?
That's what I had to do with the Buck early on, before I got better control of the air and got better at re-loading so that I didn't get too much wood gassing--I would just bypass the cat for a while until I got the load slowed down a bit.
