I posted a couple weeks back about my stove top temps getting too hot and took the advice of shutting the stove down a little sooner and I haven't seen those high temps since. Now I have a new problem. Haha. I have been shutting it down in small increments rather than all at once. I would say once the stove reaches about 400 I am 75% closed down. My new problem is that the stove seems to be putting out very little heat. Unless it's 600+ it doesn't seem to be doing very much. It's has gotten close to 600 a couple times these past 2 weeks but even then it's not the heat output that I expected when I bought this stove. Outside temps are only 30s-40s and I feel the stove is barely helping the central unit. It is an alcove set up and I know that's not ideal but it's the only way I could make it work. I have read my fair share on this website and I see people saying that stoves similar to mine will heat their entire house in sub freezing temps. I can barely get it to assist in heating my 1580sf home in South Georgia. Here are a few things that may help....
I'm burning "iron oak" I cut and split 2 years ago when I purchased stove. Moisture content is around 15-17.
When burning from a cold start I get smoke for 15-20 min, once it's going great I start shutting down until desired stove top temp. I get what I believe to be a good secondary burn. After initial start up a have zero smoke throughout my burn cycle.
I have removed a wall and I run a fan on the floor in adjacent room blowing towards the room the stove is in to try and get better circulation of heat.
Other than temps and burn times is there any way to measure the heat output to make sure the stove is operating correctly? I'm not sure if I'm expecting too much but I don't see how folks up north in much colder temps seem to be getting much better results and best I can tell this stove seems to be operating like its suppose to. Here is my setup
![TN20 minimal heat output TN20 minimal heat output](https://www.hearth.com/talk/data/attachments/220/220888-b59d2883814f67b822e0d61c537b2db1.jpg)
