I have been solving problems that I have had with my Eco-45 and this is what I have done
1. if your auger is not one of the smooth chromed one and your serial number is from the first series, contact drolet and or who you got the stove from and get the replacement auger, bushing and gasket. this makes a world of difference. I did this and I ended of with 3 of each, now I have spares, but I dought that I will need the extra 2.
2. if you get a P code, I take the rubber hose of the back of the pressure switch, and blow on it, it seems to remove any clog.
3. keep the burn pot cleaned as I have had the spot for the ignition fill with ash, but That was just me learning
4. keep your exhaust pipes clean, and I will be building the leaf blower attachment to help me with this.
I will update this post as I encounter any problems and solve them.
I am please with this stove overall, and most of the problems have been needing to learn about pellet stoves.
Update from Drolet or reset code for my stove.
The two button reset of the H1 is not working for me, so I talked to Anne at Drolet this morning and here is the reset that she game me.
Press the "Mode" button and release
Press the "+" button and release
Press the "-" button and release
Press the "quiet" button and hold for 3 to 5 seconds.
The stove will reset/or power off and all should be fine.
I will try this when I get home from work tonight![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Doug
Doug
