Tips for purchasing Firewood
A Cord is A Cord is a Cord
1. Bulk firewood is usually sold by a measurement called a cord or fraction of a cord.” A cord is defined as 128 cubic feet when the wood is neatly stacked in a line or row as indicated in the diagram below. A standard “cord” would be 8 feet long by 4 feet wide by 4 feet high.
2. Be wary of measurement terms such as “rick,” “rack,” “face cord,” “pile,” or “truckload. These terms are prohibited in some states when advertising or selling firewood or stove wood. Since these terms cannot be defined exactly, it is in your best interest to purchase firewood that is measured by the true cord.
3. Fireplace or stove wood is defined as: any kindling logs, boards, timbers, or other wood. The logs may be whole or pre-split. They may be purchased seasoned (dried) or fresh-cut. If you are buying freshly cut (or “green”) wood, be sure to allow for 8-12 months minimum for proper drying.
4. In most states, sellers are required to provide buyers with an invoice which shows the seller’s name, address, phone number, price per cord, total amount, and the type of wood purchased.
5. It is a good idea to get references from your wood seller. Buyers should write down the license plate number of the wood delivery truck. The delivered wood should be stacked (by seller or you) in a cord or fraction of a cord. Measure the stack (width x height x length) and contact the seller immediately if you did not receive the quantity purchased. If you discover a problem with your purchase, it may be helpful to take a picture of the stacked wood.
![TIPS FOR PURCHASING FIREWOOD TIPS FOR PURCHASING FIREWOOD](https://www.hearth.com/econtent/images/uploads/axe.gif)
![TIPS FOR PURCHASING FIREWOOD TIPS FOR PURCHASING FIREWOOD](https://www.hearth.com/econtent/images/uploads/cord.gif)
![TIPS FOR PURCHASING FIREWOOD TIPS FOR PURCHASING FIREWOOD](https://www.hearth.com/econtent/images/uploads/cord1.gif)
![TIPS FOR PURCHASING FIREWOOD TIPS FOR PURCHASING FIREWOOD](https://www.hearth.com/econtent/images/uploads/woodpile.jpg)
