Tips for installing a 6"SS flue liner .. with bends..
Hello One and all.
Are there any Tips for installing a 6"SS flue liner .. with bends..
Liner rubs inside the rectangular liner not too bad.
Any help is greatly appreciated!
Can you pull it up from the Bottom?? I did my 8" that way and it was almost effortless.. I lifted it high enough for two guys to push the stove in once it was high enough... Mine was 25' long...
I fed from the top and had another person below. my liner was 3' longer than needed, so I "pointed" the end and attached a rope so the person below could pull. I insulated my liner, and the outside mesh kept catching on the mortar squeeze out so I duct taped a 4" masonry chisel to my chimney sticks and spent some time breaking off the bigger pieces. My liner is a 5.5" inside a 6"x12" flue, and with insulation it was beyond tight. I "ovalized" the liner with my knee and squished it down a little to make it a doable job, not much just about 1/2". My stove requires a 6" liner so it's technically undersized but draft is not a problem.
If the chimney is on the outside wall I'd make sure to insulate/seal the bottom to keep cold air pouring down.
A liner pulling cone can help when the liner is snug.
(broken link removed)
Hello One and all.
Yeah have the old liners broken out so you can put in a properly insulated liner. Or ovalize a 7" to fit but they are hard to get through bends
