I bought a place this summer with a double door Timberline stove that I've been using as a primary heat source. It has a 90-degree bend in the pipe inside the house, heads into the wall, and then another 90-degree bend heading up to the roof, with a ~24' run to the top. It has a flue damper before the first 90-degree bend. I'm burning pine that is 20% or less moisture content.
Some things I've noticed. The stove is fully up to temp in about 15 minutes. I usually leave the doors open for the first 5 minutes, then close them but have the air vents fully open for another 10 minutes or so, then crank them down to 1/8" open. Up to this point I have only ever left the flue damper fully open. There is a flat gasket on the doors that's missing in a few spots so the stove is definitely not air tight. Within 15 minutes, the magnetic thermometer on the flue is reading between 500F and 550F and the stove top maxes out my infrared thermometer with temps over 715F.
Anyone have some tips (other than buying a newer stove) to get the most out of this thing? Should I use the damper once I dial down the vents? Am I letting the stove get too hot before closing down the vents or is it good to get it up to temp quickly?
Thanks.
Thanks.
