It's that time of year! We make fire starters in the fall - some for us, some for friends and others for gifts.
Just a few pictures of our recent outdoor activity:
Base: The base of my firestarters starts with wood noodles. These come from chainsawing wood rounds with the grain instead of cross grain.
Employ 'volunteer' cupcake tins: Tins have been sourced at rummage sales throughout the year. Take a pinch or two of the wood noodles and stick them in the cupcake tins. I have a few 'volunteer' tins. (Does anyone actually make homemade cupcakes anymore? )
Melt 'volunteer' candles: Again, candles have been sourced at rummage sales throughout the year. Melt thoroughly.
Volunteer melting pot: Sourced at a local thrift store, modified by a list member here per a sample posted here: http://www.candletech.com/general-information/do-it-yourself-wax-melter/ IMPORTANT: Do NOT heat wax above 250 degrees! Hold the tray under the spout, open valve and drizzle into each tin.
Filled 'cupcakes': I only fill about 1/3 the way up in each. If you do this, obviously, don't let the hot wax get on your hands. (Ask me how I know. )
More 'cooling' pictures: We had lots of trays setting around cooling.
Removing: Using a butter knife to remove. It helps if you oil the tins a bit - and if you have a brew handy. This is my friends hubby joining the assembly line.
Results: Some of the 'finished product'.
Results, again: A close up to show how little wax goes in each - plus a little wax on my hand.
We made 300+ "starters" by refilling the tins as they were empty and sending them through the assembly line a second or third time.
A good day was had by all.
Shari
Shari
