My brother has an old Timberline stove he is going to have a chimney sweep look at it wondering what a good stovetop temperature is to run those stoves at. Also any info about Timberline stoves would be greatly appreciated.
Why is that about the ladder and chimney brush? They dont burn clean? No secondary burn?If it has a full baffle anything over 500 with dry wood should burn fairly clean. Like Pen said try to hold it under seven hundred. And get used to using a good ladder and chimney brush. Often.
I just leaned a couple of boards of Wonderboard against the stone hearth backing. It was crude, but effective. Those clearance requirements were another reason I sold that stove. Just didn't work in that location.
Coaly, my Timberline had a UL tag that said "made in Colorado Springs" on a shield. Does that sound correct?
Coaly sounds like your a die hard timberline fan!! Whats the deal?
