I've been talking to several installers for my Seton 90 boiler. Most have not heard of using a three-way mixing valve. Even the engineers at Bethel Engineering (Where they make the Seton) state that it is not needed, however from reading these posts, I'm pretty sure that I should use one (to reduce creosote issues by increasing return temps).
Where should I have the installer place the 3-way?
Here is my setup:
Oil boiler in basement (backup heat)
Radiator heat (water)
30 Plate Heat Exchanger to boiler (basement)
Make up water / expansion tanks (basement)
Side arm Heat Exchanger for DHW w/ Honeywell anti-scald mix valve (basement)
Two Pumps (basement)
Seton is in outbuilding (former garage)
Approx 50ft of exposed pex running in garage
80ft run of Thermopex running to the house
Seton has two aquastats (on the boiler)
Thanks in advance for feedback - I see the light at the end of the tunnel, and I don't want it to be a train!
Here is my setup:
