Thought this was elm, now not so sure
bsa0021
406
Ohio
I have 3 loads so far and maybe 3 or 4 more if I want it. The pieces with the small dark center is very stringy when split which I thought was elm. The pieces with the larger dark center split easily with an axe so I'm not sure what it is. Hickory?
The pictures of the leaves are from the smaller dark center.
  • Thought this was elm, now not so sure
Reactions: Thistle and zap
It appears there are two kinds of tree there. The darker one is Mulberry or Osage Orange. Both are excellent firewood. The lighter one with the dark center looks like elm, I guess American Elm but I am not sure.
The bark and leaves sure look like both are elm species. The lighter colored wood American elm. The one with the dark heartwood is either red elm or winged elm.
I think I agree with Wood Duck. That darker one sure does look like mulberry. Where's Thistle at? He could positively ID that stuff!
The leaves on the whiter stringy 1 are for sure elm. The other looks like mulberry. Give it the sniff test to find out iffn it's red elm.
The leaf does look like elm but the wood does not. Are you certain you got the right leaf?
Yes, Those leaves in the picture are attached to the piece of wood.
I'm thoroughly baffled, but I think the red stuff will be good wood. ==c It looks pretty wet and green. Osage would be neon green-yellow when fresh...
I agree, the leaf looks to be elm.
Good fire wood. Not top or bottom the BTU list, but good fire wood.
Red stuff, not sure.
Either way, it all BTUs.
Take it if it's free ;)
Red Elm, (the dark heartwood with small sapwood ring). Grey Elm, (large sapwood ring small heartwood). Alot of the woodwork in my home is Red elm!
Absolutely Slippery/Red Elm.Flat topped ridged bark & dark color confirms it. Beautiful stuff,smells a lot like cinnamon when cutting,splitting or burning.The very first log I milled with Granberg mill in late '93 was a very large Red Elm that had died a year or so before.Main trunk,almost 200 board feet of 1" & 2" lumber,a bunch of short thick blocks for woodturning/resawed boxes from large limbs above the forks & 5 large p/u loads of firewood from the tops & branches.
The dark stuff is red elm....good wood. The lighter stuff is siberian elm, i think. It is junk compared to the red.
You scored, bsa! :cool:
I burned some Red Elm last year and really liked it. I've got about half a cord in the stacks, and I'm on the look-out for more.
I actually walked my entire woods looking for dead red elm. I managed to get about 2 cords of the stuff that I will burn this winter. The Thistle test said it was more than ready.
Some of the stuff I found had no bark left and was down to 16%. Most of the dead standing was 18-20%.
Good to hear the red elm is a favorite. I only found about a 1/2 cord of it with the remainder of the 4 truck loads the other elm and a little cherry. It will all throw some heat and I'll be about 4 years ahead.
The Red is the best wood of those three types. It seemed to burn almost as long as White Ash.
